vcc,dee,vdd,vss
Vcc = Collector supply voltage, Vee = Emitter supply, Vdd = Drain supply, Vss = source supply.
The voltages can be negative or positive depending on the the device and the circuit configuration. In circuits using NPN transistors Vcc is generally positive but if you were using PNP transistors then Vcc would be negative. In a circuit with a mixture of PNP and NPN devices Vcc take the polarity of the predominant technology used (generally it would be positive).
vcc,dee,vdd,vss
رد: vcc,dee,vdd,vss
كلام جميل جدا
dee vcc vdd vss
