mosagalzeta
26 فبراير 2012
لbios hpdv6- 3108ee ارجوكم وعاوز ال 2 bios
العميل نزل ويندوز وتعريفات من على النت فنزل فيهم ال bios وبعد ما نزلوا وسطبوا طلب ريستارت والجهاز بعدها يفتح بور من غير داتا ووجدت ان البورده بها 2 bios
xdx
5 مارس 2011
رد: لbios hpdv6- 3108ee ارجوكم وعاوز ال 2 bios
جرب تعملو bios recovery method
عن طريق usb key
mosagalzeta
26 فبراير 2012
عن طريق usb key
ممكن تقولى ازاى معلش
xdx
5 مارس 2011
you need to download bios file from hp support
exrtact the bios
You will need to copy the two files (363C.bin and 363E.bin) from the Try First folder to a FAT formatted USB flash/thumb drive (most USB drives will be formatted in FAT unless you have changed the default). The files must be in the root of the USB drive (not in any folder). Then:
Disconnect the AC adapter from the notebook.
Remove the battery from the notebook.
Insert the USB thumb drive in the slot closest to you.
Hold down and continue to hold the <Windows> Key and the <B> key.
Connect the AC adapter.
Press the 'Power' button on the notebook.
When the LEDs come on, let go of power button and the two keys held down earlier.
The touch pad LED may come on as amber (disabled) instead of the normal white (enabled).
After about 10 seconds the notebook should start reading the USB thumb drive.
While searching for the file the notebook beeped once a second.
The number of beeps varied, depending on how big the thumb drive was and
the number of files on the thumb drive, from just one beep to many.
If the file was not found, the notebook would reset itself and try again.
If the file was found then it took about 12 seconds for the notebook to load it.
No beeping sounds heard during the loading time.
When loaded the notebook started flashing, indicated by beeps every 2 seconds.
This took about 32 seconds.
