ROYL framework ARCO processes doubts
ROYL framework ARCO processes doubts:
A: 1, to adjust the head to the maximum read and write power as well as heads of various Dan dynamic flying height
2: 1, pre-amplification steering correction 2, WRRO-delay correction, the initial set head MRJOG power value, adjust each of Dan's head to read and write interlaced factor
: 1 preamp correction 2 the head MRJOG optimization, set the flux to the parameters and set the flux density to the parameter 14, calculation of the optimum magnetic density
: Calculated for each magnetic surface flux set up the appropriate proportion of the capacity of the
: Comprehensive advanced read channel optimization test
: Channel registration set five goals coefficient to confirm the data the extent permitted by
To put it plainly ARC0 = advanced read channel optimization
