Laptop LCD screen protective film knowledge
The popularity of LCD screens, give us the advantages & Convenience much, but it also has many drawbacks:
1, the brightness problem, LCD brightness, there is no high-CRT, if long-term to put the highest brightness, it is easy to make LCD panels of the lamp and backlight aging, the color cast caused by the LCD screen is generally yellow hair.
2, narrow angle LCD screen.
3, LCD screen is very fragile, it is easy to scratch, in the use of process, if there is dust and other debris falls on the screen, even with special screen cleaning cloth to clean and also very easy to scratch caused by the LCD screen in the shutdown case, it is clear to see. If you use alcohol, such as chemicals to clean the screen must have a corrosive effect, affecting the life of LCD screens.
The characteristics of LCD protective film
High quality LCD to protect the basic characteristics of paste:
1. Without glue
Synthesis of authentic use of PET technology to protect LCD paste made from glue-free ingredients are currently on the market has posted some of the protection of materials are made of imitation, only to silicone and glue combination of PET and PET did not use synthetic technology. The results of the use of time, digital products, heat the glue changes in temperature, some gel left in the LCD surface, become very difficult to remove.
2. Designed transparent luster
LCD with digital products such as laptop, digital cameras, PDA, DV, such as display brightness do not have high-CRT, but if you put the brightness to the highest long-term, it is easy to make LCD panels of the lamp and backlight aging, resulting in LCD screen color cast, usually yellow hair. At the same time, this type of surface protection of paste special treatment PET, higher light transmission, the use of effects to keep the image sharp, clear color. U.S. should choose to use with brilliant paste function to protect the LCD.
3. Increase the viewing angle screen
Liquid crystal display screen narrow perspective, as before CRT display normal inconvenient data processing and sharing of information and the use of transparent gloss paste type will increase the protection of the ordinary liquid crystal display screen 70%.
In addition, scratch resistant and anti-finger flower is the ability of the U.S. should pay attention to one place. Since the normal maintenance, for the life of the screen is also very critical.
Now an analysis of several common materials:
1, PP material (similar to plastic)
Most of this material are the first generation of protective film, soft texture and light transmission rate difference, nor would it have any scratch flower, the role of anti-wear, anti-points can only be dust, or the role of the major psychological role in big points.
Second, PET material
Optical-grade transparent polyester film (PET) plastic coating special protection, the combined thickness of paste 0.050m / m of transparent polyester (PET) release film of the composition; surface hardening treatment of 4H, good Weather resistance, low adhesion power and easy to tear, and has ultra-high optical transmittance of no effect and remove the residue. With a high degree of Ting, and the right at the large-size FPD monitor is not easy and timely paste-coated air bubbles arising from the special design, increase the aesthetics of flat-panel displays.
Preservation of the environment: in the interior ambient temperature 25 ℃, relative humidity 65%.
Magnificent original high-quality PET material has the following characteristics:
1. The surface after treatment SMART technology, wear-resistant anti-scratch
2. To silica gel layer for the tackifier compound to prevent the formation of bubbles
3. Electrostatic adsorption type, do not leave any traces of non-corrosive surface
4. Transmittance over 99%
5. To enhance the color LCD screen, the expansion of more than 70% of viewing angle
6. Effectively prevent UV
7. Can effectively absorb the most direct impact, the proper fulfillment of the protection of your LCD screen
8. Stylus can be effective in preventing the wear and tear on the LCD screen, up to 4H hardness
9. Non-corrosive adhesive, effective care of your "love machine"
10. Safe, reliable, and does not contain any harmful ingredients to human
Three, ARM Material
ARM low cost materials in general, prices high, materials are really original ARM at more than 200 yuan (14-inch reference), mainly in the fields of some special use, is currently not very widespread civilian.
1. Without glue
Three, ARM Material
