Various types of notebook models Guinness FN key functions
Guinness DELL_Fn function keys
FN + ESC: Choose the default power management mode
(FN + F2: Wireless LAN to open or turn off features DELL8000 none)
FN + F3: Power Table
FN + F8: Switch display
FN + F10: pop-up drive
FN + arrow keys up / down arrow keys: Increase / reduce the brightness
FN + END: Mute
FN + PgUp: Volume Up
FN + PgDn: reduce the volume
FN+Num lock:: Scroll lock FN + Num lock:: the equivalent of pressing the Scroll lock
ASUS articles
ASUS S200 is a combination of the following key features:
FN + F1: lower the screen brightness FN + F2: higher screen brightness FN + F3: Wait for the status of FN + F4: hibernation FN + F5: lower volume FN + F6: increase the volume FN + F7: Mute FN + F10: Switch display FN + F11: equal NUM LOCK key press FN + F12: equal press Scroll lock key FN + Insert: press the Print key equal (PRINT SCREEN)
FN + del: equal SysRQ key press FN + up arrow keys: Page Up keys equal press FN + down arrow keys: Press the Page Down key equal FN + left arrow keys: Press the Page Home button equal FN + right arrow keys: equal by Next Page End key FN + T: tensile screen
Below the previous models for shortcuts S8200:
FN + F5: increase brightness FN + F6: reduce the brightness FN + F7: turn off / open the screen FN + F8: Display the former for FN + F9: Mute FN + F10: increase volume FN + F11: to reduce the volume FN + F12: Press the PAUSE equal between FN + insert: equivalent to pressing the num lock key FN + del: equal by Scr Lock keys under
SHARP articles
FN + F2: connect / disconnect wireless card signal
(FN+F5) FN + F3: Display Switch (FN + F5)
FN + F6: Mute / lifting mute
(FN+F7) FN + F8: to increase the screen brightness (FN + F7)
(FN+F6) FN + F9: lower the screen brightness (FN + F6)
FN + Scrlk: press the Break key to equal
FN + Insert: press the PRINT SCREEN key to equal
FN + DEL: Press the PAUSE key equal
Samsung Part
Samsung's shortcut keys are very easy, provided the functions are the most commonly used, but the new X-series and the P series machines vary FN shortcut keys, such as the X10 and P25. FN shortcut keys now to introduce Coincidentally X10-based supplement that P25.
FN + ESC: Wait for status to be placed in the machine. (P25 for: FN + F5)
FN + F2: Battery status display
FN+F7) FN + F4: Switch display (P25 for: FN + F7)
FN+END) FN + F6: Mute (P25 for: FN + END)
FN + F7: open turn off SPDIF output (P25 for: FN + F8)
FN + F11: the equivalent of pressing the NUM LOCK
FN + F12: the equivalent of pressing the Scroll lock (P25 for: FN + F10)
FN + arrow keys left / right arrow keys: increase / decrease the volume (P25 for: FN + Page Up / Page Down)
P25 The following shortcut keys are only suitable for both the P25
FN + F11: the equivalent of pressing the Pause
FN + F12: the equivalent of pressing the Break
SAMSUNG has more shortcut keys are characteristics FN + F7/F8, can open or close the S / PDIF output, and turn off S / PDIF output port must save a small amount of energy in order to extend battery life.
FN key combinations association articles
FN + F3: Display switch
FN + F8: an increase screen brightness
FN + F9: to reduce the screen brightness
FN + SCRLK: press the BREAK key to equal
FN + INSERT: such as keys and press the PRINT SCREEN
SONY articles
FN + ESC: set to Wait for status
FN + F3: Mute (effective only in WINDOWS)
FN + F4: the pop-up section to adjust the volume status (valid only in WINDOWS)
FN + F5: Brightness adjustment pop-up Article
FN + F7: Switch display
FN + F12: the system is set to sleep status
FN + NUMLK: press the SCROLL LOCK key equal
FN + INSERT: equal press PAUSE button
FN + DELETE: Press the BREAK key to equal
FN + up arrow keys: Press the PAGE UP key to equal
FN + down arrow keys: Press the PAGE DOWN key to equal
FN + right arrow keys: Press the HOME key to equal
FN + left arrow keys: Press the END key to equal
FN + F: pull or not pull Shin Shin screen (only useful in under WINDOWS)
FN + END: Mute
ASUS articles
SHARP articles
Samsung Part
SONY articles
