Notebook also play high-definition video - Software Part
the software settings that can not be ignored high-definition video to notebook users is the high-level audio-visual enjoyment, but not necessarily all of the notebook users have to know the ins and outs of this thing's particularly clear, so it is not clear " both hard and soft "here. I called once to see quite a number of repair, said that when bought high-definition video look very smooth, then reinstall the system had become after "card" - in all likelihood that the software settings are not in place.
Notebook hardware configuration like a stage, may be if there is no special software to play a role, it is not tantamount to an actor on stage, you will not be able to enjoy high-definition video of this show Even if they are no longer luxury notebook configuration, if there is no installation required for high-definition video playback software, you did not enjoy very smooth picture. So, what kind of software in the end this movie is suitable for First, high-definition video encoding solutions for sorting and <br /> want to open a file, you first must know the encoding type of documents can be targeted to set up software Therefore, we must first understand the classification of high-definition video encoding. High-definition video encoding formats have four, that is, H.264, MPEG-4, MPEG-2 and WMV-HD. Now the network's high-definition video on the main circulation has two types: one is a standard MPEG-2 compression, tp and ts in the video stream for the file suffix; the other is a WMV-HD (Windows Media Video High Definition) standard compression wmv file off; suffix have a small number of documents known as avi or mpg, and wmv its nature is the same. 。 Therefore, we can not just from the file name suffix on the type of encoding that can only be realized through the decoder to identify themselves. That is to say, we have to prepare well-oriented as much as possible of the decoder, otherwise there will be some video files can not play the embarrassment of the situation.
In addition to the software decoder, such as Intel's nVIDIA's PureVideo, ATI's AVIVO decoders and other hardware, you can call the GPU's computing power to support high-definition video decoder to reduce the share of processor resources. However, relative to their needs with the driver in order to function properly. With the graphics card manufacturers will also continue to upgrade the video file in order to continuously provide the new driver to the user. Windows Media Center Edition 2005 For instance, the nVIDIA graphics cards support PureVideo in MPEG-1/2/4 encoding process, apart from its own decoding DVD Decoder software still needs some special software, at the same time with Windows Media Center Edition 2005 to achieve this function. Of course, the hardware acceleration for the driver of the decoder hardware are recognized - that is to say you do not have the corresponding hardware card can not be the installation of such decoders.
Three, the software decoder + plug-ins: one can not be less evaluation has been so high-definition video playback: First of all, the right hardware with + skills = smooth; Secondly, a good software decoder + = invincible 。 From the introduction above, we can see that for the MPEG2-TS (MPEG2 Transport Stream) format high-definition video, we not only need to decode MPEG2-TS plug-ins, but also has a special separator HDTV. The role of separator is to really identify the file format will be one of the video stream, audio stream data separated from the decoder and send it to decode treatment. DirectX even though the MPEG2 format to provide separation, but more than DirectX8 version has been canceled for the support of TS stream, it is necessary to install the other HDTV format before separator. one of the separator can be a good format to support HDTV. After the software installation, HDTV separator is also installed on the system.
It is common, the books no matter what you configure, you can install, but can have a significant performance enhancement, or to depend on the books of the hardware configuration. On Air HD Editor On Air HD Editor section are the development of Korean players, HDTV, and Internet sources are much HDTV film from Korea, so this player is also well-known result. 比起Media Player Classic Compared to Media Player Classic, it is much less want, but we need to use only its HDTV decoder.
If you think so too trouble collecting them one by one, we can consider a number of good packages have been packaged. MY MPC are the sdxy DIY version of a new dedicated high-definition video network and the development of highly integrated software package, which with its many separator, but also compared with three currently popular player - Media Player Classic, KMplyer, BSPLyer - three in any one will be able to work Most importantly, it provides a separation of user-friendliness / decoder adjust instrument - Mpeg2 Codec instrument switch, set to adjust the MPEG-2 decoder, and have been broadcast on various software optimized settings, be able to In the case of default to achieve the best results and best degree of compatibility. Through the original Mpeg2 codec switch to switch instrument Codec, also has the decoding program selection, software, repair and other functions, user-friendly; dynamically switch Mpeg2 separator 4, 8 Mpeg2 video decoder (except outside the DScaler all seven Open the hard-decoding) and 6 Mpeg2 audio decoder, with a strong ability to decode the HDTV.
Decoder can only smooth playback prerequisite for high-definition video, and advanced the next step is how to better high-definition video player - a high-definition film of the same source familiar with the players at hand can best color saturation modulation degrees as well as the sharpness, or the film to maintain the unique quality videos and so on - it's necessary for the filter settings, and different filter combinations. It can be said that the right to use filters are the soul of high-definition player. irst of all, here we recommend Moonlight popular three-piece, including the moonlight video decoder, audio decoder, as In order to ensure high quality playback of film sources, the average user will use the three settings, but not with arbitrary. Moonlight'sElecard MPEG 2 Player 。 Moonlight'sElecard MPEG 2 Player support MPEG1 and MPEG2 playback in the PC, video player software. 。 It is a GUI user interface, the Elecard MPEG2 Video Decoder, compatible with Microsoft DirectShow filters. Features include MPEG 2 (ISO / IEC 13818) video programming, and MPEG 1 (ISO / IEC 11172) system, Moonlight's Elecard MPEG Player is a real-time MPEG software player. Can play high-quality MPEG-1, MPEG-2, MPEG-4 SP / ASP and H.264/AVC file format, support MP4 system, compression VOBs, MPEG-4, DVB, SVCD, as well as procedures for many streaming media transmission Its built-in DirectShow decoder can play, such as AVI, WAV, MP3, MOV and other documents, and supports AAC, MPEG-1 Audio (Layer I, II, III), MP2, WAV input and SPDIF audio output, such as whole For the evaluation of this filter are relatively clear picture quality, and be able to save system resources effectively, so that the processor is in line with the lower, more suitable for a high number of configured users.
A headache for most of the H.264 encoder, if you configure the books do not really like on the trend, not a very smooth playback of H.264 video encoding, we recommend you CoreAVC decoder, you will be surprised to find films a smooth change, CPU's share has declined; slightly higher for the configuration of the books, and even through the decoder can play 1080p video. But of course, this is the definition of sacrifice that may arise, such as white-definition, but generally speaking, the low or H.264 video player with books the best solution.​
