damage to the hard disk module from the read and write after the repair
Damage to the hard disk module from the read and write after the repair! (Do not call the other hard drive with the original firmware and the firmware repair disk failure): When we get firmware damaged disk failure, the first read out all the modules and module groups, such as do not know better after first load LDR and ROM, not to hurry to write the firmware, after identifying the main menu, first check what modules or module groups damaged? Used under the Notes, and then just read on from a bad disk or group of modules to re-write, four module reset OK! After writing more than this such as disk failure remains impaired, it would prove that the damage to the module is really damaged the only good call on the firmware disk write back! (The reason for this is: because some modules are damaged by PC3K view, but the damage is not really! PC3K only module in the test group or module error breaking it! Too not to trust the inspection module PC3K right or wrong! Have this it will tell you good or bad, the worse it will tell you are good! There are no absolutes! experiment to prove this!!)​
future.net2013
15 نوفمبر 2013
رد: damage to the hard disk module from the read and write after the repair
