Notebook hard drive with password PC3000 solutions
PC3000 notebook hard drive with password solution
First, check your hard disk encryption status of the hard drive will be well received, PC3000AT to enter the main menu interface, press the small of the DEL key on the keyboard can be hard to see the current parameter table. : Flip to the last page, you can see the following information:
password established: yes password established: yes here if yes, that is, this disk password has been set;
If no, that does not have a password for this site.
HDD locked :yes HDD locked: yes here to indicate whether the disk has been password locked.
Sequrity level: Maximal Sequrity level: Maximal Here level password security lock;
high和maximal。 There are only two cases: high and maximal. Master At high level, Master password can be used to unlock, all the data in non-destructive; at Maximal level, can not use Master
。 password direct unlock, but with all the Erase command to write zero to unlock, all the lost data.
Master code: $ FFFE here If $ FFFE, or the Master password to this site or the factory default values;
Second, notebook hard drive with password PC3000 general solution methods to unlock:
1, if the original set is aware that the user password can be PC-3000AT At the main menu by a small keyboard under the 6 key (or right arrow keys), select "Disk sequrity commands "---" unlock disk
Enter the correct password, Enter, if prompted to unlock the success of the operation is successful; and then the implementation of" Clear password ", will be able to completely clear the user password setting, lossless data at this time.
。 2, does not know the user password set, but the Master password for $ FFFE, and Sequrity level to high, then the steps to unlock Ibid. Password But have to select a password when the Password
type: master password. type: master, and enter the correct master password.
3, does not know the user password set, but the Master password for $ FFFE, and Sequrity level for the maximal, should be the implementation of "Disk sequrity commands" - "Set
password ", enter the correct Master password, then the implementation of" Erase disk ". After removal of tens of minutes to process the data, can be used to restore the hard disk status, but lost all the original data.
4, does not know users do not know password set Master password, you need to use special methods of lifting the password.
Three, PC3000 notebook hard drive password solution to unlock the Special Ways
1, to find a disk with the same model to be declassified, and the Firmware version of the same normal unencrypted hard drive.
2, PC-3000AT with the "Set password", to set a simple and easy to remember the user password, such as "123456"; power re-power;
3, PC-3000AT with the "unlock disk", deliberately enter a wrong password (such as "abcd"), will see the prompt operation is unsuccessful. At this point, the hard drive module to preserve the correct password has been automatically read the hard drive circuit board in the buffer zone.
4, with "sleep" so hard to enter the sleep state, when the hard disk to stop.
5, carefully removed the hard drive circuit boards, for to be unlocked at the end of the disk, a good screw. Here are the live operation, require very careful! Special attention to IDE interface and power interface loosening other.
6, the "unlock disk", enter the password set in front of their own, such as "123456." clear password”, Prompts if successful, will continue to the next command "clear password", unlocking process is complete And, in exchange for the original use of the circuit board.
