بعض رسائل الخطا فى الد اف ال وحلولها
The DFL-WD [FONT=宋体]FAQs summary[/FONT]
2011/12/30 [FONT=宋体]update [/FONT]
[FONT=宋体]problem:[/FONT][FONT=宋体] prompt can not find[/FONT] c41.dll [FONT=宋体]prompt can not find[/FONT] c52.dll
[FONT=宋体]solution:[/FONT][FONT=宋体] set procedures[/FONT] c41.dll [FONT=宋体],[/FONT] c52.dll [FONT=宋体]deposited to the installation directory, usually located in[/FONT]C: \ Program Files \ CiDong the Electronic \ DFL-WD II \ [FONT=宋体], can eliminate the error.[/FONT]
[FONT=宋体]
[/FONT]
[FONT=宋体]The problem [/FONT][FONT=宋体]: Prompt the application configuration is incorrect. As shown below: [/FONT]
[FONT=宋体]Solution: [/FONT][FONT=宋体]Downloadshared in the group [/FONT][FONT=宋体], and then follow the prompts to install the compressed within the program[/FONT]
[FONT=宋体]
[/FONT]
[FONT=宋体]:[/FONT][FONT=宋体] device driver installation is complete, the device which will appear[/FONT] usb2.0 the hub [FONT=宋体]driver error[/FONT]
[FONT=宋体]Solution[/FONT][FONT=宋体] :[/FONT][FONT=宋体] in the group share[/FONT] of sp3 subhub.rar [FONT=宋体]download xp [/FONT][FONT=宋体]install compression driver within the package.[/FONT]
[FONT=宋体]Question 4[/FONT][FONT=宋体] : The program prompts the initialization error! [/FONT]
[FONT=宋体]Solution:[/FONT][FONT=宋体] Click the power switch ([/FONT] POWER [FONT=宋体]) button, you can return to normal.[/FONT]
initialization error message
[FONT=宋体]Question 5[/FONT] : [FONT=宋体]Program initialization is completed, prompted[/FONT] the runtime error; [FONT=宋体]is generally due to the run directory of the program changed the [/FONT]
[FONT=宋体]solution:[/FONT][FONT=宋体] delete the [/FONT][FONT=宋体]file to [FONT=宋体]the program directory of[/FONT] HDD.ini [/FONT][FONT=宋体].[/FONT]
كود:
[B]
system is in initialization only general function work.sure to enter..
 معناها انك تريد الدخول علي الهارد وهو ما زال Busy
رجاء الانتظار حتي تضئ لمبة DRD و DSC في البرنامج ثم قم بالدخول
[/B]​
  • xp sp3 usbhub.rar
    39.6 KB · المشاهدات: 185
رد: بعض رسائل الخطا فى الد اف ال وحلولها The DFL-WD FAQs summary 2011/12/30 update
الهارد لا يقوم باور على كابل الداتا
الحل
قفل بورتين الساتا بكابل ساتا
أمجد حشمت موسى
30 أبريل 2010
شكرا على المجهود الرائع
