One button ARCO or Single ACRO Optimization
PHP:
It depends on the situation of the hard drive.
If the patient drive has a few bad sectors, it’s necessary to run 46 optimization and then run 28 selftest; If there’re many bad sectors and are not distributed regularly, you can use ‘Write Common Repair FW’ to write universal FW modules and ROM modules, and then run 6F, 6A, 6B, 69, 46 and finally run 28 selftest. If there’s no firmware exchange and users are using the original FW modules, users can run one button ARCO (including 6B, 69 and 46 Optimization), before running one button ARCO, you can run 6A and 6F optimization separately. These two optimizations are fast and will be quickly finished.
