وصف مراحل الاركو المختلفة WD ARC0 comment
6F adjust the maximum read-write heads in all Dan dynamic power and head flying height
6A 1, preamp steering correction 2, WRRO delay correction 3, the initial set value of 4 head MRJOG power to adjust the head of each read and write interleaving factor Dan
6B preamplifier correction, optimizing head MRJOG 3, parameter set 1 and set the flux to the magnetic density parameter 14 to calculate the optimum magnetic density
69 each magnetic surface flux calculation to set the appropriate volume ratio
46 fully advanced read channel optimization test
