Bad Track substantial hard drive data restore software performance
A large amount of hard drive is a relatively trouble Bad Track thing, which a lot of important hard disk data storage when data recovery workers will feel that a headache is a comparison of things, This is necessary because the recovery time is longer, from a large number of Bad Track data look hard copy of the instrument performance, were the following:
1: In the copy of data cause the loss of the ability to work hard, pure software software for such copies can not be completed because the data or data recovery software can not reset the hard disk copy tools and the cause of failure, although some software to the hard drive has to send reset command, do not achieve the desired results, for data recovery efforts are clearly required to restart this situation can continue to copy the hard disk data.
2: Bad Track many documents cause the partition table or index, such as information loss, can not be directly traverse the directory structure information, such as data, the need for an overall hard disk drive image copy, and then extracted through the image data, although in some software with the search data search function, but also give users the convenience of a great deal, but the confusion of data or documents uneven, damaged frequent phenomenon.
3: Bad Track hard because there is substantial, often a lot of time required to copy data from these valuable customers, frequently go head to read data, the flaw to the disc caused a fatal head injury, leading to deformation, the disk data out with end-of-life, may be used to this point, "Anything is Possible" is more appropriate.
4: combination of hardware and software copy control data Recovery software instrument, and it has the power to control, flexible operation mode, so that much of the data recovery workers favored lot of friends to see often communicate using the PC3000-Data Extractor bad instrument to achieve Road data copy job, including copies of Bad Track time because it is something that we can not talk about, but the failure of this data!
Data Recovery workers from the perspective of the Bad Track substantial hard drive data recovery, data recovery, or no copies of data to reach the ideal instrument ideal speed and quality, in such cases often reflect on the quality of the worse faster, if you encountered a hard drive as to how this happened?
Postscript: First of all thank everyone concerned about my friend, my FREE on up, and thank you for everyone concerned about the Mid-Autumn Festival is approaching, I wish my side, well at Friends of the Net Line holiday Writing too much of a rush of inevitable shortcomings, welcome everyone to correct me, with everybody's mind, like a piece of jade was carved as a work of art.
