Seagate Barracuda hard drive SELFSCAN explain!
In fact, with implementation instructions Seagate Barracuda hard drive is very easy SELFSCAN specific instructions have two
1: I command
2: N command
Running on a platform of PC3000 and PC-SEGATE own WINDOWS HyperTerminal can be
In fact, what is the same platform, as long as you can be able to send commands to the hard disk, ah) then the COM line well, waiting for the hard disk model is displayed after the CTRL + T to switch the implementation of the class T Factory mode, then use; order Show hard disk information of the parameters
. For example: age = 50 type = a1 .................
Then enter, type N2,, 22, carriage return, and then press ctrl + t the implementation of the current operation
If there is no error message, then that has been launched successfully SELFSCAN
If there is wrong information, then you have the hard drive may be other modules have broken, resulting in SELFSCAN function could not be activated
SELFSCAN start at a time when the best off not to in order to avoid unnecessary troubles
The Seagate hard drive Maxtor hard drive SELFSCAN ominous, in the middle of power outages, you can add at the power plant, the hard disk will have automatic mode such as the selfscan. ctrl+t McNair's not the West, power outages, the power plant at the time add to the implementation of ctrl + t
selfscan Can continue to implement the selfscan
At the start screen after hard drive selfscan there is no change, this time, we can use the keyboard on the "." SELFSCAN order to see the process, specifically the LBA = XXXXXXXX look xxxxxxx is the process of hard disk sectors. AGE50 OK! Can also be used ";" command can also view, that is, look, AGE has not changed for at selfscan After, with access to the COM terminal, hard disk will be prompted to AGE50 OK!
These are the use of N instructions,
command the format is: I1, 1,1,22
The Seagate Barracuda hard drive for End SELFSCAN will not recognize disk repair! ! !
Seagate Barracuda hard drive in the command above is very clear about
1: If you back up to start the better you SELFSCAN hard data on the SA District
2: Hard Drive at SELFSCAN launched after the hard drive will clear the data area of the SA
3: End at SELFSCAN for the future, if the disk is not recognized, please put the data back-up area of the SA hard Back to Writing
In fact, done at SELFSCAN Barracuda hard disk, the disk is not recognized because:
MICROCODE SELFSCAN hard to do at the time, will damage the hard drive MICROCODE
In other words, the ATA interface hard drive module, then, we only need to write this from the module, you can solve this problem!
U.S. SELFSCAN make recommendations at the time, starting from the first 31,
Such as: N31,, 22 and then return, in accordance with the implementation of CTRL + T can be! ! !
1: I command
2: N command
