Head Depopping Options And Steps
Head Depopping Options And Steps Before depopping the heads, please make sure there's no damage in the fw modules.
WD HDD Head Depopping Steps: Option 1
1 Clear Smart and G-list
2 Clear Translator
3 Generate another copy by editing the OB automatically
4 Depop the head
5 Restart and then perform the low-level formatting.
WD HDD Head Depopping Steps: Option 2
If you fail to depop the head by Option 1, you may select Option 2 to depop the head.
2 Clear Translator
4 Depop the head within the head map
5 Enter the ARCO configuration interface, input 1 in the box used to lower the capacity (Input 2 if you fail to use 1), click lower the capacity.
6 Restart and the capacity and ID match automatically, perform low-level formatting and now you make it.
WD HDD Head Depopping Steps: Option 3-For Clicking WD ROYL drives
1 Modify 0A firstly
2 Find the patient head and cut 0A
3 Enter ARCO configuration interface if the HDD is detected, input 1 to lower the capacity. It can reset the current capacity and TPI to the default status according to the 0A.
4 Restart and run low-level formatting, done.
** If there’re a lot of bad sectors within the hdd, we can run ARCO at the 4th step above.
5 Enter ARCO and initialize it
6 Run ARCO
7 RUN PST, Done
Note: You need to lower the capacity by inputting 1 or 2, if there’s no error indication, you can then perform the head depopping operation for WD PCB 1640 series.
رد: Head Depopping Options And Steps
بارك الله فيك مهندس اسلام
and depopping head options steps
