Modules of Barracuda
There are just 10 main modules related to the Barracuda family. The structure of the firmware is quite simple which makes data recovery from the Barracuda family a lot easier.​
  • Module 0 ALT: This is the G-list module​
  • Module 1 ATA: This is a ATA module which stores the protocols of the ATA communication and interface. It’s a very important module. After doing a SELFSCAN (except when the flow starts from either N2 or N5), this module will be damaged.​
  • Module 2 CERT: SELFSCAN codes​
  • Module 3 CERT TAB: SELFSCAN flow - Modules 2 and 3 are not important for the normal operation of Seagate drives.​
  • Module 4 INFO: Stores the HDD parameters including the model number, SN , LBA and so on. If a change to the model number or LBA is attempted but fails, this usually indicates the the sectors containing this module are damaged or that the module has become corrupted.​
  • Module 5 PL: This is the P-list module.​
  • Module 6 TS: This is the T-list module which is the compressed version of P-list.​
  • Module 7 APP: This is a loading module. This is quite similar to the loading module 41 in Western Digital hard drives.​
  • Module 8 SECT: This is an unimportant script module.​
  • Module 10 SMART: This is a SMART module as in many conventional drives.​
budi
18 مارس 2014
رد: Modules of Barracuda
bos full pdf
barracuda modules of
