camelion
Laptop specialist
8 نوفمبر 2011
New script for unlock hdd wd
BASICALLY HERE ARE THE INSTRUCTIONS:
SOFTWARE YOU DO NEED!: zu = THIS IS THE MAGIC program. As far as I know it ONLY WORKS ON WESTERN DIGITAL HARD DRIVES (although I could be wrong). You may download ZU WD Drive Unlocker here: Add to
You will be emailed a download link after checkout. No Guarantees. No Refunds. No Support. No Returns. All Transactions are FINAL. Do not contact me about refunds. There aren’t any. I didn’t write it, it will either work or it won’t. I do not make any money from this, your small donation is used to offset server costs…
(optional) MHDD 4.5 = still need the password to UNLOCK, but it tells you everything you need to know about the state of the locked drive. Run from a bootable ISO cd or USB key. DONT USE VERSION 4.6 that is in Hiren’s Boot CD. GOOGLE AND FIND VERSION 4.5. Google the file mhdd32ver4.5.iso, and create a bootable cd or usb out of it.
1. plug the drive into an older sata motherboard computer.
2. set your BIOS sata controllers to the most NATIVE and non AHCI or RAID mode you can.
3. Boot to your mhdd iso cd that you created. This sets the DOS environment and memory manager and stuff.
4. MHDD -> press Shift+F3 and choose your drive. if its not listed then either edit \mhdd\cfg\mhdd.cfg to enable the controllers or use another computer/motherboard/controller.
5. MHDD -> Press Shift+F2 to view the drive properties, it should say LOCKED (Note: it may also tell you the SECURE ERASE time in minutes. Mine was ’80 Minutes’. this is important to note)
6. Exit MHDD with ALT+X. You should now drop to dos.
7. Run ZU. you will obviously have to copy the file over, this is why i use a USB drive to boot my ISO, i can copy the file to the USB drive, Boot my ISO using YUMI Bootloader, Exit MHDD, change dos path to ‘C:\’ and then run my C:\ZU.exe program
try them all ‘ZU /P’ or ZU /S or ZU /A, one of them should start and not error.
If you get an error or ‘Drive still locked’ msg then try a different command ie ZU /A
If you get something that says ‘ELAPSED TIME xxxxxxx’ then LET IT RUN FOR AS MANY MINUTES AS DENOTED IN step 5. I let mine run for over 80 minutes.
So, after 80 minutes nothing happeded. I hit CTRL+C and exited out of ZU.
Then I ran MHDD again, picked the drive using Shift+F3, then checked the status with Shift F2. Then I exited MHDD
FINALLY, i ran ZU.exe /P as my drive was on the primary controller. This time it worked! ZU betta reported ‘DRIVE UNLOCKED’ and i was able to now format, partition and otherwise use the drive as normal!
SUCCESS! WD SATA HARD DRIVE UNLOCKED!
ZU /P FOR PRINCIPAL DRIVER OK
YOU NEED DRIVER FLOPPY USB
  • zu.rar
    4.1 KB · المشاهدات: 79
xdx
5 مارس 2011
رد: New script for unlock hdd wd
nice post
thank you
للاسف الطريقه ناجحه في التوشيبا فقط
لان مكان الباسوورد في كل التوشيبا من قديم الازل ثابت
انما شركة ويسترن بتغير مكان الباسوورد بمعني الموديول ثابت ولكن تراكه ومكانه متغير من هارد للتاني
فالطريقه مجربه في التوشيبا بنجاح انما الويسترن للاسف بائت بالفشل
اذا كنت جربتها واتاكدت منها بنفسك
او احد الاخوه جربها اكتر من مره يبلغنا
وشكرا جدا ياباشمهندس
camelion
Laptop specialist
8 نوفمبر 2011
Yaaaaah no problme whit wd
bat you can test it
i not have the tool for unlock hdd
bat i send the new good info
camelion
Laptop specialist
8 نوفمبر 2011
OK
THIS METHODE GOOD FOR
  1. Maxtor (except STM),WD,Toshiba,Quantum
  1. Fujitsu (except MHW,MHZ,MHY,MJA). There is a mistake for MHX
  1. Nikimi (former Quantum & Maxtor
MDT (former WD
Native Hitachi (DK-xx,HTC..G7AT00
  1. IBM/HGST (many models,except 100h_byte_NVRAM & 4K-NVRAM & 2.5" with blue controllers. (mcu=ARM & B9A3..), disks without NVRAM
ExcelStore(former HGST).
Seagate(with parallel flash)+Grand(UX with serial flash).
for hdd new script unlock wd
