Samsung Burn Info
Samsung Burn Info
SAMSUNG REPAIR METHOD
1. REPAIR BAD SECTOR WITH HT CODE
- Choose HT code same as hdd model need to repair
- Download to the drive
- Once download success , connect the hdd to independent power supply
- Check the hdd led by using the led ( see the picture in Led position document)
- If fast blinking , it mean , drive are ready to downloading the BI code
- After download BI code , again connect the drive to independent power supply for 8-14 hours
- If after 8-14 hours drive stop and we must check again the led , if fast blinking , it mean drive repair good already , if slow blinking , it mean drive unprepared ( must do cut head)
- Fast blinking drive need to download the maincode
- For slow blinking need check the head
2. REPAIR BAD SECTOR WITH HTBI CODE
- Choose Fflash code and Htbi code same as hdd model need to repair
- Download Fflash , power off /on
- Entry to module operation , open and selected module Bi Scrpt , write all to zero 000000 then save to hdd , write selected to hdd
- Download HTBI code
- Connect the drive to power supply for burn in 8-16 hours
- If after 8-16 hours drive stop and we must check again the led , if fast blinking , it mean drive repair good already , if slow blinking , it mean drive unprepared ( must do cut head)
3. FIX Knocking sound
- Set the jumper to safe mode close all pin except the last pin
- Downloading HT code or Fflash depend on hdd model
- After download finish , power off /on , set jumper to normal ,
- Knocking sound should be fix , check head , which are BAD
- Set Bad head , GO , downloading Fflash
- Downloading HTBI or BI code depend on what hdd model .
  • Samsung Burn Info.zip
    134.8 KB · المشاهدات: 72
Ahmed Mohsen
13 يونيو 2011
Samsung Burn Info
رد: Samsung Burn Info
جزاك الله خيرا يا هندسة
توفيق مختار
1 مارس 2009
Samsung Burn Info
burn info samsung
