Ahmed Mohsen
13 يونيو 2011
شرح اكواد الاخطاء في برنامج wdr ومعانيها
السلام عليكم ورحمة الله
wdr error codes
0000 = SUCCESS Successful
0001 = SCT_INVALID_FUNCTION_CODE SCT function code is invalid
0002 = SCT_INVALID_LBA SCT invalid LBA
0003 = SCT_REQ_SECNT_OVERFLOW SCT requested secnt overflow
3700 = FM_ERR_FILE_INFO Firmware File Information Error
3701 = FM_ERR_DIR firmware catalog file error
3702 = FM_ERR_FILE_ID firmware file ID error
3703 = FM_ERR_CHECKSUM Firmware checksum error
3704 = FM_ERR_COMPAT firmware incompatibility error
3C00 = FMT_ERR_PLIST_NOT_FOUND plist not found
3C01 = FMT_ERR_INVALID_PLIST plist invalid
3C02 = FMT_ERR_GLIST_NOT_FOUND Glist not find
3C03 = FMT_ERR_INVALID_GLIST Glist invalid
3C04 = FMT_ERR_EXCEEDED_PUSH_DOWNS PUSH timeout
3C05 = FMT_ERR_PDLIST_WRT_FAIL pdlist WRT failed
3C06 = FMT_ERR_NEW_BAD_TRKS
3C07 = FMT_ERR_FRMT_FAILURE
3C08 = FMT_ERR_EXCEEDED_GLIST
3C09 = FMT_ERR_GLIST_WRT_FAIL
3C0A = FMT_ERR_CAPACITY
3C0B = FMT_ERR_ZSD_NOT_LOADED
3C0C = FMT_ERR_BUF_ALLOCATION
3C0D = FMT_ERR_RELOLIST_WRT_FAIL
3C0E = FMT_ERR_PDLIST_NOT_FOUND
3C0F = FMT_ERR_RELOLIST_NOT_FOUND
3C10 = FMT_ERR_EXCEEDED_RELOLIST
3C11 = FMT_ERR_WRT_FAIL
3C12 = FMT_ERR_EXCEEDED_RPDLIST
3C13 = FMT_ERR_RPDLIST_WRT_FAIL
3C14 = FMT_ERR_RPDLIST_NOT_LOADED
3C15 = FMT_PLIST_PSN_OUT_OF_RANGE
3C16 = FMT_PUSHCOUNT_OVERFLOW
3C17 = FMT_HASH_TABLE_OVERFLOW
3C18 = FMT_ERR_INVALID_ZONE_TABLE
3C19 = FMT_ERR_CANT_MERGE_PGLIST
3C1A = FMT_ERR_PLIST_WRT_FAIL
3C1B = FMT_ERR_SLIPS_EXCEED_LIMIT
3C1C = FMT_ERR_TRACK_PUSHED_DOWN
3C1D = FMT_ERR_FIELD-LIST_WRT_FAIL
3C1E = FMT_PLIST_CYLINDER_OUT_OF_RANGE
3C1F = FMT_PLIST_HEAD_OUT_OF_RANGE
3C20 = FMT_ERR_REMERGE_REQUIRED
DISK_DAM_ERROR_RANGE_RSVD 5180 =
5181 = DISK_DAM_ERROR
HOST_UNSUPPORTED_ATA_OPCODE C400 =
C401 = HOST_RECEIVED_LBA_TOO_BIG
HOST_LBA_OUT_OF_RANGE C402 =
C403 = HOST_DRV_PARAMS_SPT_NOT_SUPPORTED
C404 = HOST_DRV_PARAMS_HDS_NOT_SUPPORTED
C405 = HOST_UNSUPPORTED_FEATURE_VALUE
HOST_UNSUPPORTED_MULTI_COUNT C406 =
C407 = HOST_MULTI_NOT_SET
C408 = HOST_DIS_IORDY_NOT_SUPPORTED
C409 = HOST_UNSUPPORTED_COMMAND_IN_PST_MODE
C40A = HOST_INVALID_SECTOR_COUNT
C40B = HOST_VSC_CMD_EXECUTING_IN_BKGRND
C40C = HOST_CMD_NOT_ALLOWED_GAIN_CAL_MODE_ACTIVE
C40D = HOST_QUEUE_CMD_INTERMIX_ERROR
C40E = HOST_UNSUPPORTED_SET_FEATURE_SATA_FEATURE
C40F = HOST_QUEUE_TAG_ERROR
FFFE = NOT_AN_ERR_SIO_INVLD_NON_ATA_OPCODE
FFFF = NOT_AN_ERR_VSC_CMD_EXEC_I
رد: شرح اكواد الاخطاء في برنامج wdr ومعانيها
جزاك الله خيرا
نزل ملف ال wdm افضل
future.net2013
15 نوفمبر 2013
م/محمد نعمان
23 أكتوبر 2010
الله عليك دائما الي الامام
