camelion
Laptop specialist
8 نوفمبر 2011
Unlock Intel HM70 chipset challenge for Core i3 and i5 processors
If you upgrade to a Core i3 or i5 with Intels HM70 chipset, Intel have put some kind of timer into the HM70 chipset that counts to exactly 30 minutes and then completely shutdowns down the system, with a complete halt to fully off, and not your normal windows kind of shutdown.
This is not a problem isolated to just my particular make and model of notebook, it affects all HM70 based chipsets
Basically I have tried every tool I can find to avoid the 30 minutes timer from occurring, although no luck yet.
I am here today to ask someone to unlock the BIOS as much as possible for the Compaq CQ45-707TU that I am using in hope to find a solution.
If that can be done then I will spread the word through out various forums where there are many people hoping to beat this.
There could be a option in the BIOS that could be turned off which just might help like the HPET
Strange thing is everyone that has the HM70 know the Core i3 and i5 processors run perfectly without fault, therefore it will be a matter of turn something off, to stop the machine from shutting off very 30 minutes.
If someone can unlock my BIOS, this will be a step to beating Intel's restrictions.
Link to BIOS, this covers many similar models from the Compaq CQ45, HP1000, and HP2000 which all use the same motherboards.
17-
17-e051er (DAR62CMB6A0 rev.A)
bios see attached
  • bios 0196DF080.rar
    3.3 MB · المشاهدات: 197
ابو سارة
17 فبراير 2011
رد: Unlock Intel HM70 chipset challenge for Core i3 and i5 processors
Useful information
اخى العزيز camelion
مواضيعك دوما جميلة لكن ينقصها الترجمة للعربية لاتنسي معظم العاملين في المجال بينهم وبين الانجليزية واحيانا الفرنسية اللى بتكتب بها عداوة مطلقه
camelion
Laptop specialist
8 نوفمبر 2011
Le problème est que je pratique pas bien le clavier arabe. VHS. P
Pour se sujet
C est notre frère xdx
Qui a ce problème je voulez pas que vous déplace le sujet
La solution pour ses bios c est la d activation du mode slic
Je vais poster un programme et une explication pour cela
Hassriyan fi reepair.net
xdx
5 مارس 2011
thank you my friend
