DFL-WDII Version 2.53 Is To Be Released
Due to the new hardware and a lot of new functions are added, we are working to make the new versions work stably and excellently and within 2.53, we have had the following changes:
1, Kernel mode access is enabled and optimized;
2, ROM write is optimized;
3, New family password removal bug is fixed;
4, SPT manual getting error is fixed;
5, SF monitoring further optimization;
6, New-Within logical scan, users can start it from where it's stopped;
7, ID read failure interface optimization;
8, Optimize the Stop button and now if users click the stop button, it will stop the SF and SF monitoring at the same time;
9, FW read/write speed is optimized;
10, Program icon abnormal error is fixed under Windows XP OS;
11, As for the 25 seconds prompt, we removed it because the way the sf works is different. With the new method, users just need to start it and remove it(when the sf is running) for offline sf. The old method has some limit: sometimes sf of some drives has been started but it tells sf failure and now it won't happen.
البرنامج ان شاء الله خلال يومين
رد: DFL-WDII Version 2.53 Is To Be Released
يااااامسهل
م/محمد نعمان
23 أكتوبر 2010
ربنا يسهله عليهم ويطلع كويس
الاصدار قيد التجربة الان
