HD Platter Exchanger for spacer drive
Hard drive motor failure is normally caused by sudden power surge or accidental dropping. When it comes across this problem, the solution is to swap the platters into a working drive and get the drive repaired before data retrieval. SalvationDATA Platter Exchanger tool is specifically used for removing platters from spacer hard drives when transplanting to donor.
Features:
Properly handles physical damaged spacer drive with motor seized
Support all spacer hard drives for platter swap
Simple & Portable
Easy to operate, user friendly
Cost effective
Free tech support
World’s first platter swap tool for spacer drives
PRICE=200USD
