notebook chips commonly used models, and alternative forms
3.3V/5V or used notebook chip production is the substitution
1. MAX1632 MAX1630 MAX1633 MAX1635 MAX1902 SC1403 MAX1632 MAX1630 MAX1633 MAX1635 MAX1902 SC1403 interchangeable
2. MAX1631 MAX1634 MAX1901 MAX1904 MAX1631 MAX1634 MAX1901 MAX1904 can be substitution
3. MAX1999 MAX1997 MAX1999 MAX1997 can be substitution
4. SI786 MAX786 SI786 MAX786 can be substitution
5. MAX785 MAX786 MAX785 MAX786 is used in the boss's son. Substitution can not.
2951 LP2951 m5236 2950 Common understanding of the notebook chip linear regulator blocks: 2951, LP2951, m5236, 2950
TM87XX IBM:TB6805F TB6806F TB6808F TB62501F TMP48U Boot chip: Toshiba TM87XX, IBM: TB6805F, TB6806F, TB6808F, TB62501F, TMP48U
I/O PC97338 PC87391 PC87392 pc87393 SMSCFDC7N869 FDC37N958 LPC47N227 LPC47N267 I / O chip: PC97338, PC87391, PC87392, pc87393, SMSC Series: FDC7N869, FDC37N958, LPC47N227, LPC47N267
MAX1632 MAX1631 MAX1904 MAX1634 MAX785 MAX786 SB3052 SC1402 LTC1628 System power supply chips: MAX1632, MAX1631, MAX1904, MAX1634, MAX785, MAX786, SB3052, SC1402, LTC1628
CPU MAX1711 MAX1714 MAX1717 MAX1718 MAX1897 CPU power supply chips: MAX1711, MAX1714, MAX1717, MAX1718, MAX1897
ADP3203/ADP3415 ADP3410/ADP3421 ADP3410/ADP3422 Chip with the use of electricity: ADP3203/ADP3415, ADP3410/ADP3421, ADP3410/ADP3422
MAX1645 MAX745 MAX1772 MAX1773 ADP3806 TC490/591 MB3887 MB3878 LT1505G Chip charge: MAX1645, MAX745, MAX1772, MAX1773, ADP3806, TC490/591, MB3887, MB3878, LT1505G
CPUMAX1617 MAX1020A AD1030A CM8500 CPU temperature control chip: MAX1617, MAX1020A, AD1030A, CM8500
ATI NVIDIA S3 NEOMAGIC TRIDENT SMI INTEL FW82807CH7001A Brand graphics cards: ATI, NVIDIA, S3, NEOMAGIC, TRIDENT, SMI, INTEL, FW82807 and CH7001A
RTL8100 RTL8139 Intel DA82562 RC82540 3COM BCM440 With the use of chip card: RTL8100, RTL8139, Intel DA82562, RC82540, 3COM, BCM440
LF8423 LF-H80P H-0023 H0024 H0019 ATPL-119 LAN isolation: LF8423, LF-H80P, H-0023, H0024, H0019, ATPL-119
ESS1921 ESS1980S STAC9704 AU8810 4299-JQ TPA0202 4297-JQ 8552TS 8542TS CS4239-KQ BA7786 AD1981B AN12942 Sound Card Chip: ESS1921, ESS1980S, STAC9704, AU8810 ,4299-JQ, TPA0202 ,4297-JQ, 8552TS, 8542TS, CS4239-KQ, BA7786, AD1981B, AN12942
PC R5C551 R5C552 R5C476 R54472 PC Card Chip: R5C551, R5C552, R5C476, R54472
PC TPS2205 TPS2206 TPS2216 TPS2211 PU2211 M2562A M2563A M2564A PC Card power chip: TPS2205, TPS2206, TPS2216, TPS2211, PU2211, M2562A, M2563A, M2564A
COM MAX3243 MAX213 ADM213 HIN213 SP3243 MC145583 COM port chip: MAX3243, MAX213, ADM213, HIN213, SP3243, MC145583
H8C/2471 H8/3434 H8/3431 PC87570 PC87591 Keyboard chip: H8C/2471, H8/3434, H8/3431, PC87570, PC87591
H8/3434 H8/3437 H8/2147 H8/2149 H8/2161 H8/2168 PC87570 PC87591 H8S/XXX M38857 M38867 M38869 Keyboard chip: with the boot function: H8/3434, H8/3437, H8/2147, H8/2149, H8/2161, H8/2168, PC87570, PC87591, H8S/XXX M38857, M38867, M38869
