  • بادئ الموضوع NOOOOR
  • الردود 17
  • المشاهدات 12K
أهم مصطلحات وإختصارات اللوحة الأم
Motherboard professional vocabulary
ADIMM (advanced Dual In-line Memory Modules, senior double inline memory module)
AMR Audio Modem Riser AMR (Audio / Modem Riser; audio / modem card motherboard additional vertical)
AHA (Accelerated Hub Architecture, speed up the center structure)
ASK IR (Amplitude Shift Keyed Infra-Red, long-wave infrared mobile input)
ATX: AT Extend (Extended AT)
BIOS (Basic Input / Output System, Basic Input / Output System)
CSE (Configuration Space Enable, could be allocated space)
DB: Device Bay, Equipment Bays
DMI (Desktop Management Interface, Desktop Management Interface)
EB (Expansion Bus, Expansion Bus)
EISA (Enhanced Industry Standard Architecture, to enhance industry-standard-shaped structure)
EMI (Electromagnetic Interference, Electromagnetic Interference)
ESCD (Extended System Configuration Data, scalable system configuration data)
FBC (Frame Buffer Cache, the frame buffer cache)
FireWire (FireWire, or IEEE1394 standard)
FSB: Front Side Bus, pre-bus, that is, external bus
FWH (Firmware Hub, firmware Center)
GMCH (Graphics Memory Controller Hub, graphics and memory control center)
GPIs (General Purpose Inputs, the ordinary operation of input)
ICH (Input / Output Controller Hub, Input / Output Control Center)
IR (infrared ray, infrared)
IrDA (infrared ray, infrared communication interface may be local area network access and file sharing)
ISA: Industry Standard Architecture, the industry standard architecture
ISA (instruction set architecture, industrial settings MDC (Mobile Daughter Card, mobile formula card)
MRH-R (Memory Repeater Hub, Memory Data Processing Center)
MRH-S (SDRAM Repeater Hub, SDRAM Data Processing Center)
MTH (Memory Transfer Hub, Memory Conversion Center)
NGIO (Next Generation Input / Output, a new generation of I / O standard)
P64H (64-bit PCI Controller Hub, 64 bit PCI Control Center)
PCB (printed circuit board, printed circuit board)
PCBA (Printed Circuit Board Assembly, printed circuit board assembly)
PCI: Peripheral Component Interconnect, Interconnect peripheral equipment
PCI SIG (Peripheral Component Interconnect Special Interest Group, interconnect peripherals professional group)
POST (Power On Self Test, Power On Self-Test)
RNG (Random number Generator, random number generator)
RTC: Real Time Clock (RTC)
KBC (KeyBroad Control, the keyboard controller)
SAP (Sideband Address Port, sideband addressing port)
SBA (Side Band Addressing, sideband addressing)
SMA: Share Memory Architecture, Shared Memory Structure
STD (Suspend To Disk, the disk wake-up)
STR (Suspend To RAM, memory wake-up)
SVR: Switching Voltage Regulator (switching voltage regulator)
USB (Universal Serial Bus, Universal Serial Bus)
USDM (Unified System Diagnostic Manager, a uniform system for monitoring Manager)
VID (Voltage Identification Definition, identification authentication voltage)
VRM (Voltage Regulator Module, Voltage Regulator Module)
ZIF: Zero Insertion Force, zero-power interpolation motherboard technology
Gigabyte Gigabyte
ACOPS: Automatic CPU OverHeat Prevention System (CPU overheating **** System)
SIV: System Information Viewer (System Information Observation)
ESDJ (Easy Setting Dual Jumper, simplified dual-CPU jumper method)
Shuttle
UPT (USB, PANEL, LINK, TV-OUT quadruple interface)
Chipset
ACPI (Advanced Configuration and Power Interface, an advanced set-up and power management)
AGP (Accelerated Graphics Port, accelerated graphics port)
I / O (Input / Output, Input / Output)
MIOC: Memory and I / O Bridge Controller, memory and I / O Bridge Controller
NBC: North Bridge Chip (North Bridge chip)
PIIX: PCI ISA / IDE Accelerator (accelerator)
PSE36: Page Size Extension 36-bit, 36 bit page size extension of model
PXB: PCI Expander Bridge, PCI Bridge to enhance
RCG: RAS / CAS Generator, RAS / CAS generator
SBC: South Bridge Chip (South Bridge chip)
SMB: System Management Bus (full System Management Bus)
SPD (Serial Presence Detect, serial number detection device internal memory)
SSB: Super South Bridge, South Bridge chips super
TDP: Triton Data Path (data path)
TSC: Triton System Controller (System Controller)
QPA: Quad Port Acceleration (d interface to speed up​
بارك الله فيك مهندس محمد
محمود صالح
27 مارس 2009
khaledgad
20 أبريل 2009
جزاك الله خيرا على المجهود
