سوبر برو 500 superpro500p
متوفر لدينا جهاز السوبر برو superpro500p
الجهاز لا يحتاج الى تعريف فائق السرعه والكفاءة
نطاق واسع من شرائح البيوس
الشرائح التى يدعمها
اضغط الرابط التالي
www.reepair.net/vb
Superpro/500P USB Ultra-high Speed Universal Programmer
Hardware & Electrical Specifications:
* Supported devices: EPROM, Paged EPROM, Parallel and Serial EEPROM, BPROM, NVRAM, SPLD, CPLD, EPLD, Firmware HUB, Microcontroller, MCU, Standard Logic. .
* Packages supported: DIP, SDIP, PLCC, JLCC, SOIC, QFP, TQFP, PQFP, VQFP, TSOP, SOP, TSOPII, PSOP, TSSOP, SON, CSP, SCSP , ...
* PC interface: USB2.0
* Stand-alone Feature: None .
* Electrical spec. of the AC adapter: AC input 90V to 250V, 50/60Hz, DC output 12V/2A; power:15W
* Mechanical parameter: Main unit: Size: 178*130*40 mm Weight: -Kg.
* Packing Box: Size 320*300*85 mm Weight: 1.8 Kg.
Features:
Support devices with Vcc from 1.2V to 5V.
Extremely fast speed.
Built with 48 universal pin-drivers.
PC hosted mode and stand-alone mode. Under PC hosted mode the programmer is controlled by a PC via USB2.0 (high speed) to program a chip.
ISP/ICP programming capability available via ISP/ICP adaptor.
Only IC manufacturer approved programming algorithms are used for high reliability. (+5%~-5%) and (10%~-10%) Vcc verification enhances programming reliability.
Advanced and powerful functions.
Production mode start chip operation at the moment the chip is inserted in the socket properly.
Project function simplifies processes such as device selection, file loading, device configuration setting, program option, and batch file setting into one touch step.
Password can be set for project files and production volume control
Batch command combines device operations like program, verify, security into a single command at any sequence.
Serial numbers generators are available as standard or customer-specific functions.
Log file is useful for quality tracking.
Over-current and over-voltage protection for safety of the chip and programmer hardware.
WINDOWS XP/Vista compatibility
Speed Comparison:
Device P+V(s) Compare with SP3000U type
AT28C64B 0.8(P)+0.1(V)= 0.9(s) 1.2(P)+0.8(V)= 2.0(s) 64Kb EEPROM
24AA128 2.7(P)+1.8(V)= 4.5(s) 5.0(P)+4.0(V)= 9.0(s) 128Kb ??АEEPROM
QB25F640S33B60 29.0(P)+14.4(V)= 43.4(s) 55.2(P)+41.4(V)= 96.6(s) 64Mb ??АEEPROM
AT89C55WD 2.5(P)+0.4(V)=2.9(s) 3.3(P)+1.0(V)=4.3(s) 20KB FLASH MCU
S25FL064A 43.9(P)+14.7(V)= 58.6(s) 72.8(P)+41.4(V)= 114.2(s) 64Mb SPI EEPROM
PIC16F876A 10.1(P)+0.8(V)=10.9(s) 22.1(P)+06.2(V)=28.3(s)
PIC18F442 5.1(P)+1.1(V)=6.2(s) 13.6(P)+06.7(V)=20.3(s)
الشرائح التى يدعمها
اضغط الرابط التالي
www.reepair.net/vb
