Latest drivers: HP dv65xx-dv69xx/dx66xx/dv95xx-dv99xx, Cpq V65xx-V69xx (INTEL)
Last Updated: June 9, 2009
Inspired by dannyres's thread regarding the latest driver findings for the Pavilion dv5t, I've decided to post the latest drivers that are compatible for the following notebooks with an Intel processor below. Please let me know if you find newer drivers or other devices so I can update this post!
Compatible notebook products ("xx" denotes a two-digit number):
NOTE: All of these drivers come from HP's website, Microsoft Update, and from other reputable websites (including other manufacturers). All of the drivers here are WHQL Certified drivers, available as of the date when this post was updated. These drivers should be compatible with the notebook series stated above, but I am not responsible for technical difficulties that can occur as a result of improper driver installation!
NOTE ADDENDUM (added April 23, 2009): Following along the same lines as dannyres did with his dv5t driver thread, the process of installing and updating drivers is for ADVANCED/EXPERIENCED users only. Average users can use the drivers located at the HP support portals -- they're the safest and simplest way to go in terms of drivers for your specific model. Some of these drivers may work with notebooks other than the stated brand and models, but this is NOT guaranteed. USE AT YOUR OWN RISK -- only install these drivers if you know how to revert the changes that you have made should any problems be encountered.
Intel Chipset Software Installation Utility
Version: 9.1.0.1012
OS Support: Windows XP (32/64), Windows Vista (32/64)
Link: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=10884&strOSs=150
Notes: Even though Intel's website denotes that the desktop series motherboard chipsets are only supported, mobile generation chipsets are also compatible.
Intel SATA AHCI (Intel Matrix Storage Manager)
Version: 8.8.0.1009
Link: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17412
Notes: This version is located on Intel's Download Center website. It is highly recommended that you install this even if RAID is not configured on your system. See http://www.intel.com/support/chipsets/imsm/sb/cs-021510.htm for more information.
Intel WiFi Link 3965AG and Intel WiFi Link 4965AGN
Version: 12.4.0.21
Links:
Broadcom Wireless LAN
Version: 5.10.91.8
Links:
LightScribe System Software
Version: 1.18.5.1
OS Support: Windows XP (32/64), Windows Vista (32/64), Windows 7 (32/64)
Link: http://download.lightscribe.com/ls/LS_Update_1.18.5.1_.exe
Notes: Please make sure your disc drive is LightScribe-capable before you install this software! The latest version can always be found on the LightScribe website - http://www.lightscribe.com/
Motorola SM56 Data Fax Modem
Version: 6.12.25.4
Link: http://download.windowsupdate.com/m..._71492d84d618d6804cce1dbb5705f52be4ddcd57.cab
Notes: This driver has been provided on Microsoft Update and on the Microsoft Update Catalog. Please note that this driver must be installed using the Device Manager - Update Driver wizard. It is also recommended that you first uninstall previous versions of the driver before installing this driver.
NVIDIA GeForce 8400M GS and NVIDIA GeForce 8600M GS
Version: 185.85 (6.14.11.8585) for Windows XP, 186.03 (8.15.11.8603) for Windows Vista and Windows 7
Links:
Notes: Do not install this if you have an Intel Graphics Media Accelerator. General discussions for these drivers are shown immediately below.
Intel Graphics Media Accelerator X3100
Version: 14.38.1.5039 for XP 32, 14.38.1.64.5039 for XP 64, 15.13.1.1688 for Vista 32, 15.13.1.64.1688 for Vista 64
Links:
Ricoh Memory Stick Controller for R5C83x/84x
Version: 6.01.01.00
Link: http://download.windowsupdate.com/m..._bd4e1a3b9126338ee42a692437164bb8f76569d1.cab
Notes: This driver has been provided by the Microsoft Update Catalog. Please note that this driver must be installed using the Device Manager - Update Driver wizard.
Ricoh SD/MMC Host Controller for R5C83x/84x
Version: 6.01.01.00
Link: http://download.windowsupdate.com/m..._1b70db50d68931339c2e73b6b853cc837c3bc5c4.cab
Ricoh xD-Picture Card Controller for R5C83x/84x
Version: 6.00.01.17
Link: http://download.windowsupdate.com/m..._3e13df9abdff40a80177a8a9779e72e6053a40db.cab
Realtek High Definition Audio ALC268
Version: R2.26 (actual version information is located in the driver README)
Link: http://www.realtek.com.tw/downloads...=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Realtek RTL8101E Ethernet/LAN
Version: 5.724 for Windows XP, 6.222 for Windows Vista
Link: http://www.realtek.com.tw/downloads...d=7&Level=5&Conn=4&DownTypeID=3&GetDown=false
HP Quick Launch Buttons
Version: 6.50.1.1
OS Support: Windows XP (32), Windows Vista (32/64)
Link: ftp://ftp.hp.com/pub/softpaq/sp42001-42500/sp42309.exe
HP QuickTouch
Version: 1.00 D
OS Support: Windows Vista (32/64)
Link: ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
HP QuickPlay
Version: 3.7.6310
Link: ftp://ftp.hp.com/pub/softpaq/sp43001-43500/sp43325.exe
Notes: HP QuickPlay is required for the QuickPlay buttons at the top of the keyboard to work.
HP/Broadcom Integrated Bluetooth Module
Version: 6.2 C
Link: ftp://ftp.hp.com/pub/softpaq/sp43001-43500/sp43314.exe
Notes: Only install this if your notebook contains an HP/Broadcom Bluetooth module! This package also has limited support for Windows XP (driver only, must be installed by extraction through Device Manager).
Synaptics TouchPad
Version: 12.2.8.1
Link: ftp://ftp.hp.com/pub/softpaq/sp43501-44000/sp43611.exe
Notes: This is the most compatible driver currently available for these notebooks. Newer versions may exist and work, but they are not fully compatible with certain functions (for customization, etc).
Authentec Fingerprint Reader
Version: 7.10.1.2 A
Link: ftp://ftp.hp.com/pub/softpaq/sp41501-42000/sp41550.exe
Notes: Only install this if your notebook has a fingerprint reader!
HP Integrated Analog/Digital TV Tuner
Version: 1.3.0.69 for Windows Vista 32, 1.3.64.69 for Windows Vista 64
Link: ftp://ftp.hp.com/pub/softpaq/sp42001-42500/sp42278.exe
Notes: This TV tuner is originally made by AVerMedia. There is sometimes a newer version of the driver available on their website, however if you use that driver it will not be recognized as “HP DVB-T/Analog TV Tuner”. Only install this if your notebook comes with an integrated TV tuner.
Essential System Updates for Windows Vista SP1
Version: 4.00 A
Link: ftp://ftp.hp.com/pub/softpaq/sp42501-43000/sp42562.exe
Notes: This package includes various post-SP1 hotfixes for Windows Vista. Please make sure that Windows Vista Service Pack 1 is installed before applying Essential System Updates. It is also required that you first uninstall all older versions of Essential System Updates. I recommend these special installation instructions for new ESU packages since they don't natively support these particular notebooks:
BIOS
Version: F.59 A
Link: ftp://ftp.hp.com/pub/softpaq/sp42001-42500/sp42153.exe
Notes: http://h10025.www1.hp.com/ewfrf/wc/...areitem=ob-67682-1&lc=en&dlc=en&cc=us&lang=en
***Recent Edits (listed from oldest to newest):
03/04/2009 - Added Broadcom wireless LAN driver version 5.10.79.5 and Synaptics TouchPad driver version 12.1.0.0 (thanks dannyres).
03/10/2009 - Updated Realtek High Definition Audio driver to version R2.18 and Realtek LAN driver to version 6.217.
03/14/2009 - Updated Intel Matrix Storage Manager to version 8.8.0.1009, and added NVIDIA graphics driver version 181.22 BETA.
03/15/2009 - Added NVIDIA graphics driver version 181.71 for Windows 7 (Pre-release WDDM 1.1).
03/18/2009 - Updated Intel Graphics Media Accelerator drivers to versions 14.38.1.5039 (XP 32), 14.38.1.64.5039 (XP 64), 15.13.0.1659 (Vista 32), and 15.13.0.64.1659 (Vista 64); updated LightScribe System Software to version 1.18.2.1 (thanks dannyres). Updated Realtek High Definition Audio driver to version R2.19.
03/29/2009 - Updated Realtek High Definition Audio driver to version R2.20; updated LightScribe System Software to version 1.18.3.2 (thanks dannyres).
03/30/2009 - Added NVIDIA graphics driver version 179.67 for Windows Vista.
04/02/2009 - Updated Realtek High Definition Audio driver to version R2.21.
04/05/2009 - Updated HP Quick Launch Buttons to version 6.40.14.1 N (thanks dannyres).
04/06/2009 - Updated Synaptics TouchPad driver to version 12.2.2.0 (thanks dannyres). Updated NVIDIA graphics drivers to version 179.71 for Windows XP. Removed NVIDIA beta drivers.
04/12/2009 - Updated Intel WiFi Link drivers to version 12.4.0.21 (thanks dannyres).
04/21/2009 - Updated Intel GMA drivers to version 15.13.1.1688/15.13.1.64.1688 for Windows Vista (thanks dannyres); updated Realtek High Definition Audio driver to version R2.22, updated Realtek RTL8101E Ethernet drivers to versions 5.720 for XP and 6.218 for Vista.
04/23/2009 - Added Broadcom Wireless LAN driver version 5.10.91.4 for Windows Vista, and updated Essential System Updates to version 4.00 A (thanks dannyres and hyunf). Added note addendum.
04/25/2009 - Updated LightScribe System Software to version 1.18.4.1 (thanks hyunf).
04/28/2009 - Updated HP Bluetooth module to version 6.2 B (thanks dannyres).
04/30/2009 - Replaced the Ricoh card reader package with updated drivers, separated by components: Memory Stick Controller version 6.10.01.00, SD/MMC Host Controller version 6.10.01.00, and xD-Picture Card Controller version 6.00.01.17.
04/30/2009 - Updated HP QuickPlay to version 3.7.6310 (thanks GoodSpeed).
05/07/2009 - Updated NVIDIA GeForce graphics drivers to version 185.85.
05/19/2009 - Updated Realtek High Definition Audio driver to version R2.24 and updated Realtek RTL8101E Ethernet driver to version 5.724 for Windows XP.
05/21/2009 - Updated Realtek RTL8101E Ethernet driver to version 6.222 for Windows Vista and HP Quick Launch Buttons to version 6.40.17.2 (thanks dannyres).
05/25/2009 - Updated Motorola SM56 Data Fax Modem driver to version 6.12.25.4.
06/02/2009 - Updated LightScribe System Software to version 1.18.5.1 (thanks hyunf).
06/06/2009 - Updated HP Quick Launch Buttons to version 6.50.1.1, updated Broadcom Wireless LAN driver to version 5.10.91.8 for Windows Vista, updated HP Integrated Bluetooth Module driver to version 6.2 C, and updated Synaptics TouchPad driver to version 12.2.8.1 (thanks dannyres).
06/07/2009 - Updated Broadcom Wireless LAN driver to version 5.10.91.8 for Windows XP (thanks dannyres); thread title updated to include other products within same generation/model family.
06/09/2009 - Updated Realtek High Definition Audio driver to version R2.26 (thanks epguy3) and updated NVIDIA graphics driver to version 186.03 for Windows Vista and Windows 7.
- HP Pavilion Entertainment Notebooks
- dv65xx, dv66xx, dv67xx, dv68xx, dv69xx series
- dv95xx, dv96xx, dv97xx, dv98xx, dv99xx series
- dx66xx series
- Compaq Presario Notebooks
- V65xx, V66xx, V67xx, V68xx, V69xx series
Version: 9.1.0.1012
Version: 8.8.0.1009
Version: 12.4.0.21
Links:
- Windows XP 32: http://downloadcenter.intel.com/download.aspx?url=/17526/eng/ICS_Dx32.exe&DwnldId=17526
- Windows XP 64: http://downloadcenter.intel.com/download.aspx?url=/17544/eng/ICS_Dx64.exe&DwnldId=17544
- Windows Vista 32: http://downloadcenter.intel.com/download.aspx?url=/17525/eng/ICS_Dv32.exe&DwnldId=17525
- Windows Vista 64: http://downloadcenter.intel.com/download.aspx?url=/17542/eng/ICS_Dv64.exe&DwnldId=17542
Version: 5.10.91.8
Links:
- Windows XP 32/64: ftp://ftp.hp.com/pub/softpaq/sp43501-44000/sp43742.exe
- Windows Vista 32/64: ftp://ftp.hp.com/pub/softpaq/sp43501-44000/sp43743.exe
Version: 1.18.5.1
Version: 6.12.25.4
Links:
- Windows XP 32: http://www.nvidia.com/object/geforce_notebook_winxp_185.85_whql.html
- Windows XP 64: http://www.nvidia.com/object/geforce_notebook_winxp64_185.85_whql.html
- Windows Vista 32: http://www.nvidia.com/object/geforce_notebook_winvista_186.03_whql.html
- Windows Vista 64: http://www.nvidia.com/object/geforce_notebook_winvista64_186.03_whql.html
- Windows 7 32: http://www.nvidia.com/object/geforce_notebook_win7_186.03_whql.html
- Windows 7 64: http://www.nvidia.com/object/geforce_notebook_win7_x64_186.03_whql.html
- v185.85 - http://forum.notebookreview.com/showthread.php?p=4823276
- v186.03 - http://forum.notebookreview.com/showthread.php?t=388651
Links:
- Windows XP 32: http://downloadcenter.intel.com/download.aspx?url=/17401/a08/winxp_14381.exe&DwnldId=17401
- Windows XP 64: http://downloadcenter.intel.com/download.aspx?url=/17404/a08/winxp64_14381.exe&DwnldId=17404
- Windows Vista 32: http://downloadcenter.intel.com/download.aspx?url=/17397/a08/winvista_15131.exe&DwnldId=17397
- Windows Vista 64: http://downloadcenter.intel.com/download.aspx?url=/17399/a08/winvista64_15131.exe&DwnldId=17399
Version: 6.01.01.00
Version: 6.01.01.00
Version: 6.00.01.17
Version: 6.50.1.1
HP QuickTouch
Version: 1.00 D
HP QuickPlay
Version: 3.7.6310
Version: 6.2 C
Synaptics TouchPad
Version: 12.2.8.1
Version: 7.10.1.2 A
Version: 4.00 A
- Uninstall all older versions of ESU using the Programs and Features control panel. If no older versions exist, go to the next step.
- Download the ESU package from the link above.
- Manually extract the ESU package using an uncompression utility.
- Go to the path containing the extracted contents, and launch SilentESURunRM.bat.
- Let the batch file run; the command prompt window will disappear when installation is complete.
BIOS
Version: F.59 A
