Laptop LCD screen protective film knowledge Guinness
The popularity of LCD screens, has brought us many advantages convenience, but it also has many drawbacks:
1、亮度问题,液晶显示器的亮度,没有CRT的高,如果长期把亮度调到最高,很容易使液晶的灯管和背光板老化,造成液晶屏幕的偏色,一般都是发黄。 1, the brightness problem, the brightness of LCD, CRT is not high, if the brightness to the highest long-term, it is easy to make LCD panels of the lamp and backlight aging, the color cast caused by the LCD screen is generally yellow.
2、液晶屏幕视角狭窄。 2, narrow angle LCD screen.
3、液晶屏幕非常脆弱,很容易划伤,在使用过程中,如果有尘土等杂物落在屏幕上, 即使是用专用的清洁屏幕的布去清洁,也非常容易的造成液晶屏幕的划痕,在关机情况下,很明显就能看到。 3, LCD screen is very fragile, it is easy to scratch, in the use of process, if there is dust and other debris falls on the screen, even with special screen cleaning cloth to clean and also very easy to scratch caused by the LCD screen in the shutdown case, it is clear to see. 如果用酒精之类的化学物品去清洁,对屏幕有一定的腐蚀作用,影响液晶屏幕的使用寿命。 If you use alcohol, such as chemicals to clean the screen of the corrosive effect of a certain affect the life of LCD screens.
液晶保护膜的特点 The characteristics of LCD protective film
高质素LCD保护贴的基本特点: High quality LCD to protect the basic characteristics of paste:
1. 不含胶水 1. Without glue
正宗采用PET合成技术制成的LCD保护贴是不含胶水成份的,目前市场上有部份保护贴是仿制物料而成,只采用胶水将硅及PET 结合,并没有采用PET 合成技术。 Synthesis of authentic use of PET-based LCD technology is the protection of non-glue paste composition, the current market is part of the protection of paste made of imitation materials, only silicon and glue to combine PET and PET did not use synthetic technology. 结果使用时间一久,数码产品的热力令胶水在温度下产生变化,部份硅胶残留在LCD 表面,变得非常难于清除。 The results of the use of time, digital products, heat the glue in the temperature change, some remain in the LCD surface of silica gel, has become very difficult to remove.
2.透明光泽设计 2. Transparent gloss design
具有LCD 的数码产品如笔记本电脑,数码相机、PDA、DV 等显示的亮度没有以前CRT的高,但是如果长期把亮度调到最高,很容易使液晶的灯管和背光板老化,造成液晶屏幕的偏色,一般都是发黄。 LCD with digital products such as notebook computers, digital cameras, PDA, DV, such as display brightness do not have high-CRT, but if the brightness to the highest long-term, it is easy to make LCD panels of the lamp and backlight aging, resulting in LCD screen color cast, usually yellow. 同时这类保护贴PET 表层经特别处理,透光度较高,使用后保持影像效果鲜明,色彩清晰。 At the same time, such as the protection of the surface of paste special treatment PET, higher light transmission, the use of effects to keep the image sharp, clear color. 大家应该选择使用具有绚丽功能的LCD 保护贴。 We should choose to use with brilliant paste function to protect the LCD.
3. 3. 增加屏幕可视角度 Increase the viewing angle screen
液晶显示屏幕的视角狭窄,不及以前CRT显示屏,不方便平时的资料处理和共享资料,而使用透明光泽型保护贴会增加普通液晶显示屏幕70%以上。 Liquid crystal display screen narrow perspective, as before CRT display, the usual inconvenient data processing and sharing of information and the use of transparent gloss paste type will increase the protection of the ordinary liquid crystal display screen 70%.
此外,防刮花及防手指纹能力也是大家要注意的地方之一。 In addition, scratch resistant and anti-finger flower is the ability it should be noted that one of the places. 因为平时的保养,对于屏幕的使用寿命也很关键。 Because the normal maintenance, for the life of the screen is also very critical.
现在分析一下几种常见材质: Now an analysis of several common materials:
一、PP材质(类似塑胶袋) A, PP material (similar to plastic)
这种材质的大多是第一代保护膜,材质软软的,透光率差,根本起不到防刮花、防磨损的作用,只可防点尘,主要起的作用还是心理作用大点。 Most of this material is the first generation of protective film, soft texture and light transmission rate difference, nor would it have any scratch resistant flowers, the role of anti-wear, anti-points can only be dust, or the role of the major psychological role in big points.
二、PET材质 Second, PET material
光学级透明聚酯薄膜(PET)涂布特殊的保护胶后、再贴合厚度0.050m/m的透明聚酯(PET)离型膜所构成;表面硬化处理达4H、耐候性佳、低黏着力且容易撕下,并有超高透光率之光学效果且移除后无残胶。 Optical-grade transparent polyester film (PET) plastic coating special protection, the combined thickness of paste 0.050m / m of transparent polyester (PET) release film of the composition; surface hardening of 4H, excellent weatherability, low adhesion power and easy to tear, as well as ultra-high optical transmittance of no effect and remove the residue. 拥有高度挺性,合适于中大尺寸FPD显示器且贴合时不易包覆空气产生气泡之特殊设计,可增加平面显示器之美观。 With a high degree of Ting, and the right at the large-size FPD monitor is not easy and timely paste-coated air bubbles arising from the special design, increase the aesthetics of flat-panel displays.
保存环境:于室内环境温度25℃,相对湿度65%。 Preservation of the environment: in the indoor ambient temperature 25 ℃, relative humidity 65%.
原装高质绚丽PET材质有以下特点: Magnificent original high-quality PET material has the following characteristics:
1.表面经过SMART工艺处理,耐磨抗划伤 1. SMART process through the surface, wear-resistant anti-scratch
2.以硅胶复合层为粘剂,可防止气泡形成 2. To silica gel layer for the tackifier compound to prevent the formation of bubbles
3.静电吸附型,不留任何痕迹,不腐蚀表面 3. Electrostatic adsorption type, do not leave any traces of non-corrosive surface
4.透光度99%以上 4. Transmittance over 99%
5.能增强液晶显示屏的色彩还原度,扩展可视角度70%以上 5. To enhance the color LCD screen, the expansion of more than 70% of viewing angle
6.有效防止紫外线 6. Effectively prevent UV
7.可有效吸收部份直接碰撞,妥帖保护您的液晶显示屏 7. Can effectively absorb the most direct impact, the proper fulfillment of the protection of your LCD screen
8.可有效防止手写笔的对液晶屏的磨损,硬度高达4H 8. To be effective to prevent the stylus on the LCD screen wear, hardness of up to 4H
9.不含腐蚀性胶粘剂,有效呵护您的“爱机” 9. Non-corrosive adhesive, effective care of your "love machine"
10.安全可靠,不含任何对人体有害成分 10. Safe, reliable, and does not contain any harmful ingredients to human
三、ARM材质 Third, ARM Material
ARM材质一般性价比较低,价格偏高,真正原装ARM材质都在200元以上(14寸为参照),主要在一些特殊领域使用,目前民用不是很广泛。 ARM low cost materials in general, high prices, the real ARM original material in more than 200 yuan (14-inch reference), mainly in the fields of some special use, is currently not very widespread civilian.
