جهاز السلفجن داتا للسيجيت والماكستور الحديث HD DOCTOR for Seagate and Maxtor
يتوفر لدينا جهاز السلفجن داتا الخاص بالسيجيت والماكستور الحديث
يتميز الجهاز انه جهازين في جهاز واحد
سهولة الاستخدام
تحدديث مجانى مستمر
ضمان حقيقي
اسعار خاصة لألأعضاء المتميزين في أكاديمية ريبير
Main features of HD Doctor for Seagate:
Load Management:
Load the resource information of the drive to the program, including the drive series, model number and other parameters of the drive.
Terminal mode:
It makes it easy to monitor, view the status of the patient drive and help to make a fast diagnose onto the drive and find out a right solution. Besides you can perform hdd repair using HDD ATA commands here.
Read FW:
Backup the firmware by modules and tracks
Update FW:
Update the existing corrupted firmware with a donor one to repair the drive.
SA Scan and Repair: Diagnose, Stuff Fix and Read-only repair are included.
Defects Operation:
Clear P-list, clear G-list, disable zone, defects to P-list, surface scan, zerofill and other defects fixing features and solutions are included.
ROM Operation:
ROM read/write, you have to make sure there’s BIOS chip on the PCB, like the following pictures show (in red). If there is not a BIOS chip on the PCB, it means the ROM has been embedded in the main chip.
SELFSCAN:
Repair HD problems when you get lots of red and green blocks found by MHDD and unstable sectors. It is easy-to-operate but meanwhile it will take a long time to finish (normally 6-8 hours or even longer)
Boot Management:
Customize your own initialization, Load APP, CE Log Repair, Forced write to SA and other features are included here.
Heads Operation:
Head depop-Forward and Random head depop.
Other Features:
Seagate HDD password removal, Reset Smart, HDD configuration, Motor control, power control and other useful Seagate HDD repair features are included.
رد: جهاز السلفجن داتا للسيجيت والماكستور الحديث HD DOCTOR for Seagate and Maxtor
الرجاء ارسال السعر ولكم جزيل الشكر
للاستفسار الاتصال بالموبايل
Majd.T
7 مايو 2012
اديش السعر
tornado
8 نوفمبر 2012
كام السعر وشكرا
