البرنامج الذى ليس له بديل فى صيانه الهارد ديسك HDD Regenerator 2011
واصلاح اخطاء المديا وعلاج البادسيكتور
البرنامج الذى لا غنى عنه فى أصلاح تقل الهارد
كما انه يمكن استخدامه فى بيئه الدوس عن
طريق الفلاشه او عن طريق اسطوانه
Easily repair bad sectors on hard drive surface
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on a disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information.
As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether. When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it.
HDD Regenerator will help you repair damaged hard disk sectors without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
Title : HDD.Regenerator.2011
Filename : HDD.Regenerator.2011.RAR
File size : 7 MB
Requirements: Windows (All Versions) +DOS
License : Freeware
Freeware Date added: February 20, 2011
للتحميــــــــــــــــــــــــل
