How chang pcb wd usb3
رد: How chang pcb wd usb3
hi noooor
they are no any sound.so if head is parking out what can i do to fix it???
I only have a orginal pc3000 udma
thanks for help
you need donor and change heads
توفيق مختار
1 مارس 2009
try fist of all to swap u14and u 12 to another usb pcb .if not you have to find proper sata pcb. that's befor you start to work with HSA.what is your usb pcb number
توفيق مختار
1 مارس 2009
the sata compatible pcb with you model is 771812 .swap the rom there and try.BTW your drive family is Helois 2.5
chang how pcb usb3 wd
